What if one was able to either use the existing system for coding on dynamo;
Was able to also turn on 'command: bar' and shortcuts, as one can do so in Autocad.
It takes a few extra seconds to have to backspace all the letter in search bar and is to much for such a sophisticated software that it doesn't utilize software already created. Using a command line also seems easier when one is also running the string lines as all you would have to do is hit tab or enter to continue a workflow.
