Revit - Allow Scheduling of Groups
Residential projects often use groups as a way to manage repeated units. however there is a need to schedule these groups as a way of quantifying labeling in a tag on plan and so on. If groups were able to be treated much like most model component categories and be scheduled this would allow for simple management of Unit type for residential project and much more on just the management side of things when you need to locate and clean a model of groups.
9 Comments
JanUsinger
!!! Please Autdoesk, focus on addressing issues for which there are no good workarounds available.
This - in my opinion is not crucial to be implemented as there is an efficient workaround for this:
Just add a custom element - we use a 'Furniture Sytems' family that contains just 2D Invisible lines for it not to print - inside your group.
Add a custom Instance parameter with (values are aligned per group type) to this family and assign e.g. 'UNIT TYPE A' to it.
Create a Furniture Systems Schedule, filter for your custom 'Instance Parameter': 'Begins with': "UNIT TYPE" and you got what you wanted.
sasha.crotty
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
And Detail Groups!
harlan_brumm
Hi Everyone,
I'm pleased to say that this idea has been implemented and is now available in Revit 2018.  You can check out info on the functionality here:  https://www.youtube.com/watch?v=V5ynad04vuU .  Thanks for contributing!
The Factory
Tarek_K
Status changed to: Gathering Support
Tarek_K
Ability to Create a Group Schedule for Organization
Hi, @vitorbortoncello ,
This was implemented in Revit 2018. Do you mean something different?
Revit - Allow Scheduling of Groups - Autodesk Community
That was it. thank you
