Revision Block Row Height
While the idea to fix schedule row height was implemented the autodesk team indicated that the revision block Row Height modifier should be a separate entry for ideas.
We don't want to get into cheat ways of doing this as it has a tendency of backfiring spectacularly.
I would like to formally request a modifier for Revision Schedule Row Height in revit so we can closely align our title blocks to others?
Thanks in advance
4 Comments
JFLe5
Yes, one of the main reasons to have this feature, is to be able to match the graphic of let's say a Gouvernement title block (where they have a fixed size). Most title blocks have been designed in AutoCAD, where line spacing is defined! Trying to match this in Revit is sketchy! Plus, we usually cheat text style height (again coming from an official CAD standard).
In the end, the result is not an exact match to the original title block AutoCAD file received by the client.
lfesslerBDUQ2
The cell heights can be changed in Revit 2024:
However, this is not possible in revision schedules:
Is it possible to add this features ?
Lilian
Tags (4)
pmeyerLSRXV
great idea!!
Phil-Pleiss
BUMP!!!!!
We really need the ability to customize the row height in Revision Schedules. Currently we have to "guess and check" the font style height to get this to fit and then it doesn't match AutoCAD because the font is a different size.
