Show only
Search instead for
This will only add clicks for everybody. You will click "no" instead of clicking "reveal" again to turn it off, so no gain, but everyvbody that wants to turn reveal on must click another time.
I agree with that, but this "little" mistake in huge projects take about 30-50". Solution could be additional checkbox as "ask "are you shure" or not" in revit settings.
May I suggest a better solution: setup keyboard shortcuts. I use the temp hide/isolate commands very often (and encourage others to do the same). High use means you should have shortcuts (which would also have the benefit of keeping you away from the adjacent reveal icon). I use IE, IC, HE, & HC (and LP to reset - a throwback to our "Layer Previous" AutoCAD command) for most users, and 88, 82, 48, 42, & 6+ for myself (I mouse left-handed & keep my right hand on/near the num pad).
