Reveal hidden elements in multiple views at once
Currently, the only available method involves manually opening each view to unhide hidden elements, which can be quite time-consuming. With the right tool, this process could be significantly streamlined, making it much easier and more efficient to manage visibility across multiple views.
1 Comment
Mike.FORM
This would be nice as a right click option "unhide in selected views" and it brings up a UI that lists all the views the element is hidden in and you can check the ones you want.
