Rethink Hatch / Fill Patterns
Isn't it time to devise something a little more modern for patterns? Hard to believe that the 35 year-old PAT file format is still the "technology" of choice for this. Would love to see a modern pattern creator that could do any kind of pattern. Including: rectilinear, random, and especially radial. It is just silly that we have to use model lines and arrays or material hacks to simple brick arches or radial floor patterns.
A new pattern technology and editor please...
118 Comments
SamBerk
@devon_jackson or can you use pyRevit
We like Hatch22 for the same thing.  There is also a somewhat trickier option from a European developer called HatchBuilder.  The second one is free.
Smart hatch Creator, being able to control the line weights, the pattern, repeating, modifying, etc. I still don't get why we have to get through AutoCAD to import hatch patterns that more often than not are not scaled and not adapted to the project. I really think it is the right time to rethink the whole process, a lot of time would be saved!
There is plugin to avoid going to cad but still there is a lot of room for improvement
Currently, the only way to have a custom hatch pattern is to code one yourself.  This is an extremely tedious process, and a lot of time could be saved if there was just an option where you could simply dimension a sample tile to whatever swath you wanted to show, draft a pattern, and then the pattern would fill that tile automatically, and therefore populate any shape.  Would be much appreciated.
I don't know if anyone from The Factory has looked at the pyRevit "open source" tool on GitHub. It has a Pattern generator I'm sure they can get the code from & further develop it from there into their own for this purpose. How bout it Autodesk?
strongly support this idea!!!
shivraj.panaich
I would like to see better drafting/model patterns. More importantly the ability to create more patterns inside of Revit in a intuitive way.
Another dialogue box cold open up where you sketch a desired layout and Revit corrects if needs to for repeatable pattern in case of user error.
e.g. creating a different type of brick bond other than the standard stretcher. Wood deck with 1/3 offset. Tile patterns and configuration.
dplumb_BWBR
Agreed. It would be good to have this inside REvit. I believe there are already Revit Idea posts about this topic.
In the meantime, you might want to check out pyRevit. It has a very nice & simple Pattern Generator.
http://eirannejad.github.io/pyRevit/
shivraj.panaich
@dplumb_BWBR Just had a look at link you sent. Wish I could use that but currently using Revit LT which doesn't allow external plugins. Other than that that would have been a really useful tool to use.
Thanks for the suggestion 🙂
lionel.kai
lionel.kai
FYI, pyRevit 4.5 can also export existing patterns.
honewell
This! how has Revit not improved the usability of hatches/patterns? this is basic and has always been a problem.
we've just started using a free plug-in called pyRevit that has a feature to create a new hatch pattern by drawing it in a drafting view.  seems to work pretty well.  pyRevit seems to have many features Autodesk would do well to incorporate.
craig
Its still 2018 and this has over 800 votes and STILL no implementation into Revit. What the heck has to be done for the developers to listen to users ?????
IS ANYBODY OUT THERE !!!!!
CUptmor
We got partial success with Double hatch patterns in 2019. I hope this continues to expand.
MikaLei
Revit hatch/fill pattern is quite limited. You can create diagonal, vertical and horizontal line or crosslines based fill patterns. But if needed something else, have to import from AutoCAD as pat. -file or create with 3rd Party add-in.
Should have possibility to create inside Revit with it's own tools like detail lines etc. At the moment I use 3rd party add-in inside Revit, but I would like to keep my Revit UI so unify and clean as possible more add-ins you need to use and install, more unclear UI comes. At least this kind of basic stuff like creating own hatch/fill patterns should provided by Autodesk already.
Tags (4)
pascal.robben
"pyRevit" add-in has a very nice script for this.
Creating drafting and model patterns from simple revit lines.
Would be great if this can be implemented as a standard revit tool.
awasyliw
Just came here to say the same thing about PyRevit.
A very useful plugin for Revit and would be great to see Autodesk adopt a number of its features.
MikaLei
Actually "pyRevit" is add-in what I use also and you guys are right it having really nice script for this. There is also many other nice stuff on that add-in. That could be great if Autodesk would adopt its features as standard Revit tools. Installing separate add-ins to make basic stuff it little bit annoying.
