Restore the contextual Options Bar for MEP creation tools (Pipe, Duct, Conduit & Cable Tray)
Problem
Revit 2027 removed the contextual Options Bar that appeared while creating Pipes, Ducts, Conduits and Cable Trays.
In previous versions of Revit, the most frequently used creation parameters were available in one compact location directly below the Ribbon. This included values such as:
  • Diameter / Width / Height
  • Elevation
  • Justification
  • Level
  • Offset
  • Other tool-specific creation options
This interface allowed MEP designers to modify these parameters instantly while modeling, without moving the cursor away from the drawing area.
In Revit 2027, these settings have been split between the Ribbon and the Properties palette. Some options remain on the Ribbon (such as Offset), while others, including Diameter and Elevation, have been moved to the Properties palette. As a result, parameters that used to be available together are now scattered across different parts of the interface.
Impact
For MEP designers, this is a significant workflow regression.
When designing piping, ductwork, conduit or cable tray systems, sizes and elevations are changed continuously throughout the day. It is common to switch between multiple pipe or duct sizes and elevations hundreds of times during a project.
The previous contextual Options Bar provided immediate access to all of these parameters in a single location, making modeling fast and efficient.
The new workflow requires additional mouse movement, extra clicks, and constant switching between the drawing area and the Properties palette. This slows down daily modeling without adding any new functionality.
Suggestion
Please restore the contextual Options Bar for MEP creation tools (Pipe, Duct, Conduit and Cable Tray), or provide an option that allows users to enable the classic workflow.
This is not a request for a new feature.
It is a request to restore an efficient and well-established workflow that many MEP professionals relied on every day.
The previous design significantly improved productivity by keeping all frequently used creation parameters in one place during modeling. Bringing it back as an optional interface would preserve the benefits of the new UI while allowing experienced users to continue working efficiently.
Summary
One of the key goals of Revit 2027 was to improve performance and streamline the modeling workflow. However, removing the contextual Options Bar has had the opposite effect for many MEP users. It was one of the most efficient parts of the interface, providing immediate access to frequently used creation parameters during modeling. Restoring it as an optional feature would preserve the modern UI while allowing experienced users to maintain a fast and efficient workflow.
6 Comments
Pamela.JimenezM
Please restore the contextual Options Bar for MEP tools. When drawing pipes, we need to see and modify the diameter and elevation immediately in one visible location. Moving these controls to Properties and the ribbon requires more clicks, interrupts the workflow, and significantly reduces productivity. Please restore the original bar or allow users to enable it as an optional interface.
lhauswirth
Commenting here to increase engagement with this post, as recommended by Revit Support, in hopes that the software design team will reconsider this change.
Removing the Options Bar adds clicks, slows workflow, and creates unnecessary friction for MEP designers. The previous workflow was faster and more intuitive for tasks we perform repeatedly throughout the day. I strongly support restoring the contextual Options Bar for MEP creation tools.
jgombert
Observer
Removal of the contextual options bar is a significant hinderance to normal, efficient duct system design. Please restore this functionality as soon as possible. Looking for property values in multiple places when they have been in one concise location for many, many versions of Revit is a big problem for those of us who have to use the software to actually produce design content day in and day out. As noted this is not a request for a new feature. It is a request for restoration of an existing, integral part of MEP design.
Susana_Duarte_LMSI
Yup... Why fix something that was not broken, when you have a backlog of stuff to fix from 10+ years ago. That fix has broken stuff even beyond just the button position - it has broken the tools (see the problem with changing MEP type when fittings have shared components issue that started in R2026).
leszekgrzeczkowskiY9S4Y
Community Visitor
changing diameter of whole pipe branch with 100's of fittings is a nightmate now. Sometimes i have to do it couple of times per day. I've stopped using Revit 2027 recently and get back to 2026
t.archambault
As usual, no consideration for MEP users. Except when it's time to pay.
