Resize View/Sheet Set Window
Allow the View/Sheet Set dialog box to be enlarged.
2 Comments
Status changed to: Accepted
Accepted:
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
Susana_Duarte_LMSI
@kimberly_fuhrman-jones , please merge with:
View/Sheet Set checkbox window to be scalable - Autodesk Community
Also, very important: I'm not sure witch window this is referening to, but I really like that the "Publish Settings" window from the Collaborate tab be reviewed. It least to have the following:
- Freeze the headers of both top and bottom selection lists.
- Make second column bigger by default (to show all the text) and maybe just forget about the last column that is always empy anyway...
- Make the top selection list show more than just 4 items by default (specially if there are more than for items already)
- Make the top selection list height editable.
Please make these simples changes ASAP in your next patchs for all version of revit. Thank you!
After all 3 year to implement such a simple request that was already acepted is a bit too much, right. This should not be rocket science like some other requests here.
