Rename Shared Parameter in Project Browser with right click
Similar to how you can rename a view by right clicking on it and then  selecting to rename, the ability to rename a shared parameter in the same fashion. The Current methodology is to select the view and edit the shared parameter in the properties as required.  You can then select other views and change them to the updated shared parameter. By allowing the right click option you could do a whole group of views at the same time.
