The Ability to rename plate types. This seems to be hard coded with no way to edit.
This link shows a workaround method towards the bottom in a screen cast, but requires you to create a duplicate Type name. This can be problematic down the road when creating schedules as which "type" to I actually use the top one or the bottom one ?
https://forums.autodesk.com/t5/revit-structure-forum/plate-type-parameters/td-p/9557955?lightbox-mes...
