Adding Objects to Design Options
Editing a group has a very convenient 'Add to Group' and 'Remove from Group' command that lets you add or remove objects to/from the group while you are in the process of editing. It works great.
It would be fantastic if design options could function in a similar fashion!!!
56 Comments
It's a simple, small idea, but useful I think. We currently have a designated button that takes an element from the Main Model and adds it to a Design Option Set ("Add to Set"). But there's no method of removing an element from a set and putting back in only the Main Model besides deleting it and copy/pasting, which doesn't feel as legitimate as adding it does. It may work for components like furniture, but when it comes to walls and such, you have to verify that the heights are correct and that it's attached to the appropriate elements around it.
Just add another button: "Remove from Set".
jkidder
copying and pasting back to the main model also removes phasing, which is a pain, especially in complex projects.
jan
Yeah, copy/pasting should not be the 'preferred' workflow - that's a non-starter in any project beyond schematic. There are forum posts addressing/requesting this simple thing going as far back as 2007...
Tupaia
Stumbled of the fact that elements cannot easily be removed from Design Options recently, too. The cut/paste workaround gave us a good headache.
This is simply missing, and should be implemented! Thanks!
briantXZGBN
Agreed, so tired of these common sense functions being absent from Autodesk products.
arq.dulcegalvez
Community Visitor
Yeap, I totally agree, they should create this function. Listen up yo! Autodesks programmers. Please create this button
Rick.Aspin
I absolutely agree, please add the ability to remove objects.
frank.teslik
Observer
This is absolutely ridiculous!!!!!
Agreed
Autodesk at it's best. Create a Tool and not finish it !
kcannon7SM62
Just started working with design options. First thought: this will make so many things easier! Second thought: why can't I remove an item from a set once I've put it in there?
Autodesk, please add a "remove from set" option!
This is ridiculous to be honest.
craig
Great idea!
Are they serious?  How can they possible release this without the option to remove?  They have such a strangle hold on the software monopoly they simple just don't care.  'Give them slop, they'll eat it.'
knoc knoc! Is anybody here?! ... Autodesk?!
s.donmezHWX8P
Observer
Absolutely crazy that this function is still not available.
Fully agree. WHO creates these functions? Certainly not users of Revit. Autodesk, please hire seasoned Revit users to review every function in your products.
jpowell7
I completely agree, as well. Still no solution from Autodesk???
edgars_miskins
Oh, great.
6 years later. This is still not fixed.
Why do we even pay the exorbitant subscription fees?
Ephippus
Agree, but don't you just go into the set and cut it out?
