Rebar: Make independent within array, just as Autodesk inventor can....
When you put down an array of rebar, there is sometimes one or 2 bars that needs to be cut, moved or removed because there is some reason why the bar cant be there. This could be for some cast-in object or a recess or whatever. The current rebar tool only let you stop the array, to make a new one again after the object.
Within Autodesk inventor, when you make an array, you can select 1 instance in the array and make it independent, so you can move and/or modify that instance, but the rest of the array is stil in tact.
Please add this to Revit too, as the current rebar module in revit is wááy too limited in what you can do.
3 Comments
As additional information:
Here an example when you want to be able to move 1 bar independent from the whole array, so you dont have to break the array of reinforcements.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
