Rebar layer parameter by default
Revit should have a rebar layer parameter by default for defining slab rebar location: Bottom rebar row 1, bottom rebar row 2, top rebar row 1, top rebar row 2, supplementary extra rebar row 1 / 2, etc. Similar for walls: vertical rebar inner face, vertical rebar outer face, horizontal rebar inner face, horizontal rebar outer face. Other layer should be for spacers and/or ties. Sofistik has such option.
In large elements like slabs or concrete cores there are lots and lots of rebars. Assigning all those rebars to a partition doesn't help too much. Rebars and rebar tags together is just too much for one single drawing. We need to split-display rebars across multiple drawings by using rebar layers. We need to display certain rebar layers in certain drawings for technological reasons and resource scheduling/management.
Hiding rebar marks manually is just too tedious and senseless. 'Filtering rebars by layer' option would be awesome.
5 Comments
I know of a another 3rd party developing a tool to do exactly this is at the moment and will be available in May
ipselute
@Alan.johnson1970 : Let me guess: Graitec or Symetri's Naviate REX.
I could do it another way: add a comment to each rebar distribution or rebar group (like top 1 , bottom 2, etc),  then create filters for each such comment (like "if comment = top 1", then rebar color = black, otherwise rebar color = white). But i'd have to create many such filters, then create a view template for each of the filters (in order to be able to replicate the results to other views, other slabs, other walls or other projects). This is doable, but i find it very "manually", very programming-like. Very time consuming. As an engineer, i don't want to waste my time on such procedures, i need it to be built-in the software (call it OOTB if you like). That's a programmer's job.
Conclusion: If Sofistik is doing it, Revit should do it too. By default.
ipselute
@Alan.johnson1970:Could you please take a look at this idea too: https://forums.autodesk.com/t5/revit-ideas/dedicated-button-for-rebar-chairs-and-rebar-spacers/idi-p...
It would really help me a lot is such command would be available.
I will pass this request to relevant team.
Alessandro1985
You could assign a different schedule number to every rebar layer and use that in the view filter, it's pretty fast
