read-only
read-only
If I want to open a file just to read, it is not possible. I actually only need to look at the project, make a few cuts here and there, and check the drawing, but I do not intend to change anything. Our draftsman updates the plans. In Autodesk AutoCAD you can open this as 'read-only'. Can you arrange this here as well?
4 Comments
Hi, @loesAGYTH ,
There is the Autodesk Viewer, which allows you to view models without changing them. Does this resolve your idea?
Ric_Weber
Not only the Autodesk Viewer, which works great, but you can install and run the Revit Viewer without a license as well.  So, yes, there is a Revit Viewer.
loesAGYTH
Observer
It is not necessary for me to install the reader program anymore, because I have the full version.
But sometimes I just want to "open" and "read only".
Is that possible?
RLY_15
You don't need to install Revit Viewer. It's already installed as part of your installation of Revit. Just search for it in your taskbar.
