Show only
Search instead for
Can you please confirm? This is not the designed behavior. It should be per viewport and that is the behavior we see. Is this print and export to PDF? If you can reproduce this we would look into it as a problem report. We can post some examples if that helps? Note: import and link of pdf ang images is always raster and is a separate issue, so this will not work as test for what format Revit output was in. https://forums.autodesk.com/t5/revit-ideas/link-and-import-pdf-as-vector/idi-p/9163867?search-action...
