I want access to the Railing Extension type dimension adjustments so we can make them have presets in the type properties that look like we want when we lay them out. Manual manipulation is still good but we need some properties to be able to set them so we are not doing this every time for every railing we place on a stair. Currently there is now way to use a type field that lets you type in the dimension you want, without unpinning the handrail and adding in a extension that doesn't let you have access to the dimension that's from the floor or the height of that element either. please see attached PDF example.
