Revit seems to be unable to completely label property line arc segments. Plats that I have received have a chord length and a delta bearing on them as well as the other parameters. If those metrics are important to surveyors, why are they not in Revit's parameters for creating the property lines and scheduling and tagging? Please look at this post from landarchBIM.com: https://landarchbim.com/2014/10/03/property-lines-and-tagging-arcs/ It explains how you can retrieve the information from the drawing and accurately label a Property Line arc segment. Surely one should not need to go to this amount of effort and still be prone to mistake. This should be corrected in Revit.
