I would like to be able to create a key schedule of project information data.
Specifically in my case for consultants contact information that then could be put into a field within the project information and then into a title block. For instance, the multi-line text field for MEP Engineer could look at a project information key schedule populated with all of the engineers name, address, phone, etc. You could choose which MEP engineer you're using on this project. That would populate the project information and then you could use that information to populate labels in a title block. Hope I'm explaining this well enough.
Another use could be for listing jurisdictions and what codes they are currently using. If the key schedule had all that info, you could simply state that you are in xyz jurisdiction, and it would know which version of IBC, IPC, NFPA101, IECC, etc. you need to design to. That information could then be fed to a title block label and be pre-populated.
Thank you for your support!
