Print - Default should be "Combine Sheets into single file" or allow cancelation
In the print dialog, the default is to create individual files. This is rarely a good idea, especially if you have  set of 150+ pages.
Furthermore, there is no way to cancel the whole operation if you accidentally let it print your 150 pages individually. You have to sit there and say cancel 150+ time or forcefully close and restart Revit, assuming you had remembered to save before.
I would suggest you use "Combine Separate Views/Sheets into a single file" as the default.
Also, give us an option to cancel the whole printing operation when we make the error to print the pages individually. This is a large source of frustration in the office and it could be solved easily.
40 Comments
The "Combine multiple selected views/sheets into a single file" radio button is checked by default in the print dialog. Once you make a change to the Print Range it changes to Create Separate Files.
What I would like is for the Combine... button to be checked at all times. The only way Create separate files should get checked is if you manually check/change it.
Tags (3)
samuelsanf
I think this option must be by default, but no always... sometimes is useful
m.voss.alvine
this needs to be stored as a user preference.  you may prefer it always be checked, others may prefer it to be unchecked.
@m.voss.alvine
True, I will revise my suggestion to be that it stays wherever you put it. The erratic behavior of it jumping back and forth is what is frustrating. If I set it to ‘combine…’ it should stay there, no matter what other settings I change or whether or not I open and close the project.
Presumably most people have a workflow that they stick to 99% of the time. In my case I always print one big multi-sheet pdf.
This is actually one of the new features in Revit 2018 after years of complaints.  Not the ability to have Combine Multiple as the default.  But the printing process can be canceled by hitting the escape key and canceling all sheets printing.
AND it even pops up a warning when you hit print, warning you that you are printing 150 sheets individually.
I would agree that the combine multiple should be the default though.
samuelsanf
There was an similar Idea, but was Archived few days ago... I think this is not too hard to do for the developers, hopefully they take in count this time.
https://forums.autodesk.com/t5/revit-ideas/always-combine-multiple-selected-views-sheets-into-single...
loboarch
I merged the archived idea with this newer one.
lionel.kai
I would prefer "Combine..." be the default, but wouldn't mind if it just remembers the previous setting since what we print will sometimes vary based on the job. If we have multiple models to print from (and the sheets need to interleave), it's easier to print separate files with an "X" prefix and then just combine them sorted alphabetically (since Revit doesn't have a batch print to speak of). In ALL other cases we print combined (which also preserves links). NO MATTER WHAT, it should NOT change based on the Print Range setting!
Another option would be to move the "File" panel to the bottom (below Print Range, etc.) so that it's more natural when reviewing settings (top-down) instead of having to go back up and basically review the dialog twice.
I don't actually mind about the default, it just really needs an option to stop the printing if it goes by page.
Else it means cancelling 150+ pages manually or restarting Revit and going back from the last save. THAT's the dangerous part.
samuelsanf
sasha.crotty
Based on the comment above from @Anonymous, I am marking this idea as implemented. The ability to cancel the entire job for a multi-file print/export was added in Revit 2016 R2.
Please see: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
lionel.kai
For the part of the idea that ISN'T implemented: PDF Printing - Combine Multiple problem
AnthonyLDB
Why doesn't Autodesk just add the publish menu found in AutoCAD for years.  At least that would give users the option to print individual sheets or publish to a multi page set.
chris.jones9VA3R
I don't understand how this idea was marked "Implemented" in 2017. Maybe now the screen starts at "Print Together" but as soon as you change any other settings it switches to "print seperately" which is even worse than being the default. Probably once a week at least I almost print bogus sets because of this issue.
Default should be "Print Together" and after adjusting other print settings it should REMAIN "Print Together". Not sure why it switches out, but it's really irritating.
lionel.kai
@chris.jones9VA3Rthe problem is the "OR" in the idea title. R2016 R2 allows you to cancel, so technically they "implemented" this idea. 😞 If you make a new one re-posting just the default part, I'll vote for it. 🙂
chris.jones9VA3R
Agreed @lionel.kai
The default option should be "Combine multiple selected views/sheets into a single file."
That should be the default option and it should not change when moving from sub-menu to sub-menu. It should only change if the other option ("Create separate files.") is manually selected by the user. Is this where I "re-post" so you can vote for it or do I post this somewhere else? I am not a forum wizard.
lionel.kai
Hey@chris.jones9VA3R, this is a great way to get your feet wet submitting ideas! Just click on the "Submit Idea >" link on the right near the top. Pick a good title that concisely captures the idea, then include a clear description of what's wanted (& why) in the body (the way it is now, what should change, the problems it causes, etc.). Including a screenshot (like the OP does) would be good (even for a simple case like this), and link back to this one (to note that it's a partial re-post of this idea). You can play around with formatting a little bit and look at the preview.
After it's posted, put a link to it here so people can find it easily. 🙂
Then, next time you have a Revit Idea, after searching for it first, do the same! If there are related ideas, post the link to in those. You'll be a forum pro in no time!
chris.jones9VA3R
Currently, when printing in Revit, the 'File Settings' default to "Combine multiple selected views/sheets into a single file." - which is perfect - as discussed previously in the forums here:
https://forums.autodesk.com/t5/revit-ideas/print-default-should-be-quot-combine-shhets-into-single-f...
Unfortunately, after selecting different 'Printer Names', views in the 'Print Range', or 'Print Settings', the 'File Settings' switch to "Create separate files."
This should not happen. Print settings should not change when going from one menu setting to another. Print settings should remain as selected unless manually changed by the user. As noted by @lionel.kai. Please fix. It's really annoying - especially when I'm in a hurry and forget before printing a 100 page document.
Hi, @chris.jones9VA3R ,
Here is a similar Idea...should I combine this one with yours?
PDF Printing - Combine Multiple problem - Autodesk Community
Thank you for your submission!
Kimberly
chris.jones9VA3R
Hi Kimberly,
It's not clear to me he is referring to the same issue, but I can't quite tell. I feel like it is the same issue, but the way he words it makes me think it's not - so, I don't know. Sorry I guess that's not very helpful.
Chris
