Predominantly Flush Valve Supply Systems, correct GPM for ≤5FU
I am trying to fix the issue of The default software code written to convert "Fixture Units (FU)" to "Flow (GPM)" via Hunter’s Curve does not account for fixture units below 5FU for "Predominantly Flush Valve Supply Systems." It currently assumes 15.0 GPM for anything  ≤5FU for “Predominantly Flush Valve Supply Systems”
Please develop the .dll file and .addin file so the Flush Valve System has the correct GPM for under 5FU so it does not assume 15.0 GPM.
To see more, please see these two posts.
https://forums.autodesk.com/t5/revit-mep-forum/pipe-annalysis-revit-pipe-sizing-flow-gpm/m-p/6951000...
https://forums.autodesk.com/t5/revit-api-forum/usermep-calculation-addin/td-p/4968174
4 Comments
Autodesk:
This is a no-brainer. Please fix
Scott_D_
Seconded, a source of great frustration!
nora.swanson
Absolutely needs to be fixed - can't utilized built it functionality without it!
jstirlingJE9ZH
Any update here?
