There is an existing Architectural Keynotes feature , that works fine for Architects. It is NOT what I am requesting, and entirely different than the problem we need solving.
As MEP engineers, we need to point at things on our sheets and label them with a key. That key references a keynote legend off to the side near the titleblock. This legend tells you something about the object we have called out. Some keynotes are object specific, area specific, or just in general. Some are unique to one sheet, and others may be re-used across many sheets. Some keynote labels need to be in the same physical location from sheet to sheet, plan to plan, or level to level.
Like Legends and Views, it would be nice to be able to setup a list of keynotes in Project Browser. The Keynote would consist of a Legend with that legend's sub-notes (Keynotes that belong to a legend). They can belong to more than one legend. Drag the individual sub-notes onto a sheet, or a model view. Some sub-notes will be model view specific, showing up on whatever sheet that view is dragged onto. Others are sheet specific. However, Legends are only added to Sheets.
General Notes, would be a subcategory of Keynotes. They are similar, but do not have sub-keynotes that label objects. General notes can be added to sheets like a legend. Both Keynotes and General Notes as a feature helps us to be consistent across many sheets, and edit the notes in one location instead of on each sheet.
