Parameters Service
Parameters Service
In the same line as the New Parameters Service was made to make our life easier, however the first let down that we find when trying to use the service is that there is not an option to upload parameters from an existing file (CSV or TXT).
9 Comments
mike_engel
Thanks for investigating the Parameters Service -  I'm happy to say we do support this ability today.  You can direclty upload from a txt today.  More details can be found at https://youtu.be/17nhhyEtx3c?si=pvVNdkuRbufqNtlA in our help videos.
Thank you @mike_engel , glad to see that button exists.
Ric_Weber
@mike_engel Since this feature actually exists, shouldn't this idea be marked as Implemented?
@Ric_Weber @angelica.rodriguez.3d , consider it done! Thank you, @mike_engel for the reference.
nielsbleijenburg
Given the topic of this forum, I believe my question fits here. I uploaded a set of parameters to the parameter service. However, some of these parameters are no longer valid or need to be removed. Is it possible to delete parameters from this service?
@nielsbleijenburg , you will probably get a faster response on the Revit Architecture forum. Would you like us to move your comment there?
Ric_Weber
@kimberly_fuhrman-jones I'm actually wondering if the ACC forum might be better?
@Ric_Weber , either one, I'm sure. @mike_engel ?
mike_engel
Any location is fine.  The short answer to deleting Parameters in the Parameters service.  We only Archive Parameters or Soft Delete a parameters which is you feel is no longer needed.   If it becomes needed in the future it can be un-archived to support use.
