Parameter binding
Parameter binding
For Mep projects very often needs to bind parameters according to a certain logic. For example, a control device and a control object. When changing a parameter in a control object, it is necessary to automatically change the monitored parameter: when the parameter value of one object is used to construct the parameter value in another. In addition, it is not possible to monitor the fittings assembly of ducts and pipelines assembly from a linked model.
