Option for Family Symbols in Shedule list instead of low resolution image.
I'm quite a newby and trying to make shedules for our template.
Accept the option for Images in the Shedules which are not working properly. (auto scale images no possibility so had to make low resolution images to keep them small)
I would like to see an option I make a shedule list and when you have a symbol row it auto select the revit family symbol instead of a selected image.
Or if better options are available you can reply.
1 Comment
I agree completely. Currently you can add Famly: Generic Annotations, but it only give the name in schedules not the annotation. Autocad even offers this with tables. This makes symbol legends so much easier.
As for your resolution issue. If you set a view with white detail lines to frame the width of your symbol cell and then use this view for your export with the symbol centered on the white lines, it will create the width constraint for your image at that scale allowing the auto size works well. I did this for lighting fixture schedules on a Template.
