This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Non-rectangular Scope Box
We have non-rectangular crop regions.  Can we please have non-rectangular scope boxes so we don't have to copy/paste the non-rectangular crop region to 30 views.......
163 Comments
SzyKo
@miguel.fonsecaTPHUPYES!!! - https://youtu.be/Em4hG_yO7gU totally agree with you, but it's like throwing peas at brick wall ;P.
kcannon7SM62
I think I've done all of one building in my career so far that could be easily split up into rectangular regions. Please add a non-rectangular functionality to the scope boxes!
JKRevit
Harlan/Sasha;
A non Rectangular Scope Box seems like a mundane upgrade, but so is a Spell check tool, and Revit still doesn't have that either. I could better accept some of Revit's long standing shortcomings if someone on the development team could explain why an upgrade is difficult from a programming standpoint.
duane.smith
There actually is a spell checker in Revit. I don't remember when it was introduced, but it was at least by 2018. After you've added your text, you can either select the text or start a text command again, and then check out the "Text" category under the "Modify" tab.
[cid:image001.png@01D7A58F.C03600F0]
I think it's a little strange that the spell checker is not available while you are typing - it's really only available for editing text, but it is there. And as a terrible speller myself, I can attest, that it really comes in handy. If you have some text selected, It will start with that and ask if you want to scan the remainder of the text in that view. If you have nothing selected - say on a sheet, and just start the text command, you can check the entire sheet.
lionel.kai
@duane.smith I've found it's better to run spell check on the PDF as the built-in Revit checker only looks at actual "Text" (not Tags, View Titles, etc.). Some related to that:
849 votes:
Auto-Spell Check - Autodesk Community
336 votes:
Spell Check in Schedules - Autodesk Community
andybonesz
This idea would be great and seems like a foundational issue for creating and organizing sets of drawings.  I don't see how this is less of a priority than something like generative design, which strikes me as a very fluffy feature.
SzyKo
@andybonesz  and the answer is: AUTODESK... 🤷‍♂️
bkoolen
It would be really helpful to have the option to customize scope boxes. At this moment the only option we have, is a square/rectangular cube. If we are able to use the sketch tools to size and form our scope boxes, we can easily separate the parts we want to show in a floor plan/on a sheet, from the parts we don't want to show. For example this would be useful in an apartment building with different residences and common areas. Or to set a scope box equal to the outlines of a key plan. At this time we use masked regions to hide the parts we do not want to show on a sheet. This takes time and effort. Much easier and more efficient if custom scope boxes are added to our set of possibilities in Revit!
Apartment not rectangular shaped
Common area in the core of the building, not rectangular shaped.
Example: Apartment building with common area in the core of the building.
Red line: Available "normal sized/shaped" scope box. Green Line: Not available "custom sized/shaped" scope box.
crapai
We hear you, users. Don't worry in 2023 we have improved our generative design tools even more!
SeanSpence
Don't blame Autodesk, Blame your cable TV company! It was them who started the business model of focusing all actions on getting new customers and ignoring the old, then jacking up the costing knowing you had no options, Autodesk just adopted it!
J.Dirkse
hzaluskyJULN9
@SeanSpence True.
Trying to convince my spouse in software engineering to get into Autodesk so he can stand up for useful ideas. Autodesk's reluctance to fix basic issues like this is so so so so so so frustrating. How many thousands of votes does an idea need before they decide that it's necessary?
SzyKo
@hzaluskyJULN9
I believe it's not due to lack of willingness on the software engineering part of the Autodesk team but due to the mindset of management staff - "we won't do ****, and people will still buy our software, because they depend on it"-kinda...
p.oneillHGEVD
Observer
It would be great if there was an easy way to do partial 3D sections (if there is, please let me know). The current workaround is very time consuming and imprecise. Would it be possible to add an inverse option to scope boxes and then have them nest inside each other?
To explain, just as a scope box allows you to see everything within its boundary, the inverse scope box would cut everything out of its boundary. You'd be able to intersect them to create partial 3D sections; kind of like a boolean operation in rhino, but it would be adjustable on the fly.
The image below demonstrates what I'm talking about. It's a 3D view, but there's a section taken out of the corner. Doable, but clumsy and time-consuming.
wr.marshall
@kimberly_fuhrman-jones please combine with https://forums.autodesk.com/t5/revit-ideas/section-box-not-just-box/idi-p/6936767#comments
@p.oneillHGEVD mentions scope boxes, but I think he is after inverted 3D boxes as discussion in link
timmcgui
Observer
6 years later and still nothing! How many useless changes have been implemented in that time but something as valuable to EVERYONE is ignored because Autodesk cant figure out how to do it.
mcorbittK4VR4
Will we ever get non-rectangular scope boxes in Revit? It's 2022. I need them now.
dhassell6F2WZ
Observer
Any updates on this topic?
@dhassell6F2WZ ,
It has not yet been added to the Revit Public Roadmap. Follow the Roadmap or join the Preview Release (email revit.preview.access@autodesk.com) for more up-to-date information on what our product teams are currently working on and provide feedback.
Thank you!
Kimberly
adBZHQZ
Je propose d'autoriser la réalisation d'une zone de définition autre que rectangulaire.
Lorsque nous avons plusieurs bâtiment en L, le quadrillage ne se met pas bien et se chevauche avec le quadrillage d'autres bâtiment.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
