Being able to asign multiple slab span directions to a slab would be extremely helpful. Oftentimes the framing layout requires the slab span direction to change within a floor plate. With this, you need to do one of two things...either break the slab up at all of these changes, and have several different slabs on one floor, which is messy and cumbersome...or you cannot rely on the modeled span direction to necessarily be correct when cutting live sections and we are often re-drawing the decking. It would be great if you could assign boundaries within a slab profile to set several different span direction areas within one slab profile.
