• Real-World Requirements
Conduit routes frequently change because of coordination, site conditions, equipment locations and cost-driven design changes.
Designers need to adjust important XYZ positions along a conduit route without disconnecting the system and redrawing or reconnecting affected sections.
• Current Revit Problem
Changing the elevation of a conduit segment, fitting or connected item can move the entire connected system, including elements that are already correctly positioned.
For example, where conduit connects two manifolds, changing the elevation of the first manifold will also move the conduit and the second manifold.
To make a local adjustment, users may need to disconnect the system, reposition the required elements and then redraw or reconnect the conduit.
• Proposed Solution
Introduce an Edit Conduit Path mode using editable control points.
Users should be able to:
When a point moves, Revit should automatically recalculate the affected conduit length, angle, bends and connections without moving correctly positioned elements.
• Benefits
This would make conduit modelling faster, reduce manual disconnection and redrawing, improve coordination and preserve conduit properties, connections and scheduling information.
