Model vs. Detail line
There seems to be a missing "property" when selecting a line that tells you weather that line is a Model, Detail, or Symbolic line, shouldn't this show up in the Properties menu/ panel?
6 Comments
richardsachs4475
When selecting lines it would be helpful to be able differentiate model lines from detail lines in the project environment and model lines from symbolic lines in the family environment with the selection filter. In a view where there is a mixture of them it is not always easy to tell which is which when you've selected more than one.
Tags (2)
Kimtaurus
It would also make a lot more sense if Detail Lines were found under Annotation Categories and Model Lines under Model Categories.
Right now when you want to hide Model/Detail Lines, you can only choose to hide all the lines (or hide a Linestyle).
darrenpedder
Can we have some sort of obvious way to tell which lines are which just by clicking on them ? E.G. Model lines are listed as "Lines" and Detail lines are still listed as "Lines".
I think this is an issue also.  If you hover over the line, it will tell you if it's a model or detail line.
But if you select multiple lines and use your filter to try to deselect a certain type (Either model or detail), they both show as Lines category.
This should be fixed immediately.
Simon_Weel
If you select a line, it's properties do show up in the Properties panel under Graphics.
It says: Detail Line followed by a (grayed out) checkbox. When checked it's a Detail Line and when unchecked, it's a Model line. I don't think many people notice this, so there's definitely room for improvement...
Brian5TAQZ
It would be beneficial to be able to have separate categories for model and detail lines when using the filter. In the image attached, I have 1 model line and 1 detail line selected, and the filter shows both lines in the same category.
Tags (5)
