Material Tags
Material Tags
When using materials tags it is extremely hard to tag material changes on the same wall such as wall base, paint and wood paneling etc. There are two thought that come to mind to fix this one being able to adjust where the material tag is pointing to such as 2 ft, 4ft etc. The better solution to would be when placing a tag on a wall with multiple materials, you should be able to press tab and that would cycle through all the materials on that wall.
Best,
Zach Norman
