Mass modeling
Mass modeling
I hope in the future versions of revit simplify the mass modelling and reduce steps  of extrusion modeling like sketchup application, it's hard and take a time to create a void on an exist geometry then cut the two geometries, and if I want to create the same void in other side of the exist geometry I should do the same steps again, but if I can draw some lines or rectangle or circle on exist geometry then I can push or pull like sketchup it's very simple and quick, thanks
1 Comment
Being able to slice and push/pull is what makes FormIt and Sketchup so intuitive. That should be the de facto standard for modelling planar geometry in most CAD applications now. I would extend this feature to Components as well, so long as they retain the ability to lock to reference planes.
Autodesk Customer Advisory Groups
