Make Spaces Work Better
We constantly encounter space bounding issues and bugs within space colour fill legends, which are hidden within a process that's supposed to be simple and efficient.
This is that much of a problem for us that it has put our engineers off spaces completely and they have reverted back to hatching around areas like you'd do in CAD when producing zoning drawings, not good!
It would be better if the Revit code could reference the Architectural room geometry more closely, which works fine within the linked Architectural model.
When a space colour fill legend is applied, sometimes the colour disappears from certain spaces for no obvious reason and often the fix is to click the link, untick room bounding then switch it back on again afterwards i.e. a bug in the software.
We are an MEP company and have these issues with all of the Architect's we work with, so I don't think this can simply be put down to 'user error' when the results are consistent.
I appreciate this is a complicated issue but I think it needs to be addressed.
2 Comments
Hauk-Morten
glenwalson7986
It would be nice if Spaces could still read the Room Name and Number even when Room bounded floors are present. When a Spaces is created on top of a Room bounded floor that extends past the level line, the extents of the Space never fully reaches the level line and doesn't read the Room information. Setting the floors to non-room bounding in the Architects model does fix this issue, but that is rarely done by the Architects. This has become more of an issue when using ACC because we know don't have access to the make any changes to the Architects model.
