There are a lot of time when elements get modeled in the wrong workset and/or level.
When we try to move the hole model between for example Workset1 and the correct workset, it takes forever, if revit doesn't freezes in the end, and we even risk losing information (like fittings taps) or getting stuff disconnected.
We are just changing one property value that has no implication in the view we have open...
Why is this so painfull?
The same with changing the level, even when both levels have the same elevation, so the element doesn't even have to move or recalculate. We again get lots of disconects all the time.
Why???
Can you not make this a simplers operation? Please?
I lose days of my life with tasks like these, that should be so simple. How can we explain this to our clients??
How do you?
