When you open "Edit Assembly," the pop-up menu is a bit stubborn. Could we separate the "Finish" and "Cancel" buttons so you don't keep hitting "Cancel" when trying to click "Finish"? Maybe place the other menu options between them or something similar. Since the program often stutters a bit when you try to click, the pointer often ends up somewhere other than where you intended. A few other places where similar things could be done.
