Linework tool
Linework tool
It would be nice if the linework tool only modified the portion of a line that is visible in the view. I'd keep the ability to drag the endpoints of the line to a desired position, just 'smarter'. With it's current capabilities, I often forego using the linework tool in favor of drafting heavier lines over the model.
4 Comments
hstaabprime
I was just about to suggest this as I discovered what appeared to be a bug, but given that it's been a persistent issue since at least 2005 per forum posts, it must be a feature.
It does not seem to be intuitive or desirable for the linework tool to behave this way.
For example, in elevation view, when using the linework tool to change reveal lines to a lighter weight line style, it brings the entirety of that line to the front of the view. In instances in which the reveal is on a wall obscured by another wall, this poses a problem.
Also, for large models lifework tool becomes slow to the point of being unuseable.
Gerard4016
Observer
This really needs to be addressed... why have the linework command if it doesn't address the issue it is used to solve.
Susana_Duarte_LMSI
And the fact that we lose the ability to control endpoints if the line we want to override is a section/cutable line of the element (and not a line in view) is a nightmare. It really make the tool almost unusable. I only use it for permanent underlay line of reflective ceilings and for stairs endings (to make the line lighter like the pavement hatch pattern)...
