Level Head Automatically Change Text Justification Dependent on Which End
If the level head is turned on to the right side in a view, a multiple line level name looks fine, but if it is on the left side, then being right justified is wrong (in my opinion).   I want the text to justify dependent on which end it is on.  So if the left side is on, it should justify to the left, so the text remains up against the symbol.  On the right side, it should right justify so it is aligned up against the symbol on that side.
Most of the time with single line level names, it doesn't seem to be an issue, only with the occasional longer level names.
1 Comment
Mike.FORM
That is interesting, I always thought the level head family mirrored itself depending on which end since visually it grows correctly for single line but I guess it does something different.
Another option may be to be able to assign different heads to the left and right ends.
For now thought you may want to revise the level name to read "T.O' WALL AT E/W ENTRIES" so as to avoid the double line.
