The keynoting system within Revit is good at identifying objects (connecting the drawings to the specifications) and how they’re being used commonly throughout a project. What it does not do well is identifying objects that are common but are used uniquely throughout a project. There are two ways to overcome this issue:
Therefore, I would like to suggest the ability to add an Instance Parameter text field to the keynote family. Not only will this allow for various uses to be identified, but it will also assist at identifying different finishes for a given product. For example, if multiple finishes of a solid surface counter are being used throughout a project, the keynote would read 12 36 61.A2 SOLID SURFACE COUNTER TOP SS-1 (SS-2, SS-3, etc). If a change to the keynote text is required, it would be done once, versus three times, without changing the finish identifier.
Chris
