Issue - when linking Revit files with other Revit files, the host file does not populate the Keynote legend from the Keynote Tags in the linked file. The work around is to create a per project keynote legend, and filter out what you need. This becomes very labor intensive and limited due to filter options. It would be far more efficient if Revit would just allow you to populate a per sheet keynote legend, in the host file, that would include linked views.
This was a previous topic that is still valid. People normally uses links in order to contain individual 'units', 'house types' or bedroom types' for projects with such as hotels, apartments, hospital rooms, senior care facilities, etc.
