KEYNOTE SCHEDULE FORMAT
ADD THE POSSIBILITY FOR MULTILINE, HELPFULL IF YOU NEED BILINGUAL NOTES FOR EXAMPLE, AND GIVE THE POSSIBILITY TO OVERWRITE FORMAT ON INDIVIDUAL FIELDS OR ROWS FOR EXAMPLE RED FOR VARIATIONS OR ANYTHING ELSE.
3 Comments
akumburakis
Sorry for all the caps, was by mistake. Furthermore I meant overwrite directly in sheets, because if you use filter by sheets, conditional format is not useful due to "varies".
@akumburakis , thank you for your idea! I think this is a combination of multiple ideas which may be better posted separately. Here is a similar idea for multiple text lines in schedules:
https://forums.autodesk.com/t5/revit-ideas/allow-schedules-to-display-multi-line-input-properly/idi-...
MiWolff
While slightly unwieldy the keynote schedule, which I understand to be the text file involved with keynotes, already supports multi line text. Editing the file outside a text editor in a spread sheet application of your preference is recommended though.
