Instance parameter wrapping at wall terminations
A common issue I have when detailing is needing to hide a wall in a detail view. It seems this could be very easily remedied by providing an system instance parameter in the wall families which would allow one to make the wall terminate without having to unjoin walls, etc... In the eclosed snipped image, both walls are unjoined, but because wall wrapping is turned on as a type parameter, there is not a way to easily terminate the wall and prep it for detailing.
Any additional thoughts on how to remedy this are much appreciated.
7 Comments
I agree, having wall wrapping as an instance parameter would be great. The only thing you can do at this time is to duplicate the wall type and create one type as with wall wrapping and one without wall wrapping.
Thanks Ric!
Steve_Th
 Also it would be important for the wall wrapping to be controlled by one end or the other. I believe as a type parameter it currently affects both ends. I believe it also affects the top of the wall and the bottom too. So, ideally there would be a few instance parameter check boxes if this were to be done properly.
Great point! - hadn't thought of that.
Adam
Lamb
AIA
Senior Project Coordinator
DIRECT 404 949 2352 CELL 404 932 6268
Beck Architecture LLC
3500 Lenox Road, Suite 250
Atlanta,GA 30326-4229
404 949 2300
This e-mail may be privileged and confidential. If you are not the intended recipient, please delete from all computers.
sasha.crotty
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
