Improve the ROtate command and it's keyboard shortcuts
The Rotate command in Revit could use some improvement.  Here's some suggestions:
The center of rotating is quite often wrong.  It seems to assume something like the centroid or middle of the object, not the insertion point.
I'd like to see is some quicker way to place the center of rotation.  You shouldn't have to click a button in the ribbon to do that.  Ideally you could get revit to automatically have you set the center of the rotate.
The fact that spacebar rotates a single element is nice, but it only works on one single item at once.  It should work on a group of items....say you want to rotate 50 lighting fixtures 90 degrees in place at once, it should do that.  This spacebar rotation should be available in both clockwise and counterclockwise and it should be able to assume nearby angles like tabbing during placement does.
One more addition I'd like to see in rotate would be a "Rotate in plane" option, which would allow you to say take a pipe, draw it in plan view and then rotate it to be vertical easily.  You shouldn't have to be jumping to sections all the time to work vertically.
4 Comments
we need to have some facilitation in using Revit.
why we do not have (or why we can not create)  short cuts for the most common angles in rotation (as 45,90,180,) , to save more time while working.
as RO90 / RO45
dplumb_BWBR
You don't have to click on the "Place" button.
You can just drag the grip as soon as you start the Rotate command.
Ironically enough,  dragging used to be the ONLY way you could move the center point
The Place button was added because just the drag wasn't obvious enough .
dplumb, thanks for the tip.  Didn't notice that grip.  Makes it slightly better.  However it should be insertion point not middle.
Also I want to correct myself, you can rotate a group of items using spacebar....but only 90 degree intervals.
It would be nice to be able to rotate by say 22.5 degree or 45 degree intervals.
Beltman-SvG
I mostly use the R3 command in Revit to Rotate so you can select the rotation centre in one go.
To be able to set more default rotation angles would be nice.
