Improve Rebar
Improve Rebar
- Ability to Multi-Join: select and join multiple objects (if possible). Here also the possibility to give priority to a certain family (no switch join order needed anymore).
- Incorporating Marks into ordinary tags. For example, cross-reference in Word...
- Leave reinforcement on a surface - not perpendicular to the direction of the reinforcement itself AND later still adaptable (possibility to make 1 tag of it)
- Steel connections are currently not user-friendly. A lot of work to make a simple connection.
- Giving bars an end alignment. For example: end vertical align or horizontal align. This way you don't have to use a cut by face each time = very cumbersome.
- Add rebar multiplier
