Show only
Search instead for
The line pattern setting for Guide Grids only affects the outline of the grid. It would be helpful to have it change the pattern of the grid itself so it doesn't have to be solid lines running through the drawings.
You mean something like this?? In Continuous, you set the end segment line type and you can have any type you want. If you set the Center Segment to Customer you can have all sorts of fun!
If this is not what you are talking about, let me know.
