Wish to have the option in the visibility setting for Floor to not show the floor boundary lines, particularly projection lines. The problem is in a plan view we would not want to see floor boundary lines, it makes the drawings look messy with all the extra lines. The current workaround out there is either to make the floor projection line white but they print white too so there would be white lines overlapping with black lines. If Revit has in the Print Option not to print white then this solution could work. The other option is using linework tool and manually go in each view and pick the lines but when there is 100 views to go over this is quite time consuming. Really hope Autodesk can incorporate either add floor boundary lines in the visibility setting or in Print Option add an option not to print white lines would greatly help!!!!
