Flattened curved elevations / sections
When elevated, curved surfaces do not show the full length of the wall.  Moreover, graphics become skewed.  We would like to be able to wrap an elevation tight to the curvature of the wall so that the elevation appears to be a flattened out curve.  You could do this by offsetting a line from the curved wall and picking that line as the elevation path.
53 Comments
AnthonyViscusi
Please also allow an option to include column grids which intersect the view depth to be displayed for reference.  I anticiapte that you might need to implement a "parallel offset view depth" option so the curved view cutplane and depth plane remain consistent.  Whichever grids intersect this cutplane would be rendered.  At least make them show up then we can element hide the ones we don't want to see.
to have the ability to create a curved section
GHASEM_ARIYANI
Hello
It can not be a standard
But the technique can create mass
then join mass with revit elements.
curved section
This would aid immensely in CD phase with curved buildings. From a construction point people want to see the "flattened" version of a curved wall in elevation (otherwise one can't measure on it). In 2017 one still has to make those kind of views by hand, and that's a very tedious and time consuming task.
 ‎05-19-2017 05:08 PM |
exactly!
I'd like to add that it shouldn't be limited to just one curve. What we basically need it being able to make a section or elevation like a 'polyline' (that supports linear AND curved subsections).
In Belgium, we call these types of elevations/sections 'flattened'. Basically, you project everything against a chosen polyline 'surface'. Right now, that's a fully manual job in cad, that takes a lot of man hours and has to be completely redone from scratch when there's a significant design change.
AHMED.ELNASHAR
To create sections using poly line or curved line/axis.
this will help in adding details - drawing extractions for model curved towers , cylinder stairs , block walls.
Tags (5)
For MEP "long sections" are a similar thing. This is the straightened out section along a pipe, even as it bends, so you can see its relationship to other pipes that pass over and along it and to the ground above. As per @pieterschiettecatte, this requires a polyline path with linear and curved parts.
https://www.revitforum.org/mep-general/19710-long-section-long-profiles-section.html
Yes. we need this feature
Why We Can't Take a Curve section?!!
dplumb_BWBR
Because geometry
jdelaney_kearch
We've been building curved stairs for centuries without curved sections. A curved section would only be a geometric abstraction anyway, and would probably confuse the contractor to no end.
YarUnderoaker
Instead of curved section may be better to do a wrapping surface, for example, room's bounding walls.
Not sure how a curved section would work if the view has any depth at all. The stairs beyond the section mark would have to ... there would be multiple vantage points ... looking in different directions at the same time... Wait! ... I think I finally understand Cubism! Thanks!
In all seriousness,  and I know this is Ideas not the Q&A forum, but this is when you use a drafting view to draw the stair run in section.
BIMAbhi
Curved section: Is it possible to draw a curved section in Revit in order to show curved walls and ramps.
Tags (1)
DWAIPAYAN3010
In Revit, while creating a section, the section is linear in shape. However, in Revit 2020, the elliptical wall is being enabled newly.
It would be much helpful if users can have curved sections as well.
Tags (2)
Curty102
Seems possible, but the section would not have a "beyond" extents.
Do u know how to use curve section in Revit?
We create excavation shoring plans.  Shoring elevation views typically "develop" walls, that is, show the actual wall lengths on the drawings instead of the orthographically-projected views.  Civil-engineering software has done this forever for things such as road alignments.  It seems that Revit should have had this functionality years ago.
stephen_whelan
On numerous projects we are working on at the moment we are being asked to produce developed elevations along the length of retaining walls and secant walls where the walls either kink off a different angles slightly or are curved. While in some cases we can use Revit sections to stack views to create the impression of a developed elevations, it would be a great time saver for our projects if there was a function within Revit that would allow us to produce these efficiently. A further application could involve our Bridge teams as they are starting to use Revit more but are also finding it limited for developing complex elevations and section.
Has this request been raised with Autodesk before and if so was there a technical reason it could not be implemented? Or is this somewhere on the Structural road map?
