Please fix the ongoing problems of how railing 'Top Rails' and 'Handrails' transition around the inside corners of stair landings. The old railings used to be pretty bad at handling these transitions, but the newer 'Top Rails' are actually much worse.
Refer to my blog post on this subject:
weird-stuff-with-revit-railings-top-Rail
We need Revit to be able to create a very simple transition around tight corners - because that is how they build them on site, especially on fire escape stairs where space is kept to the absolute minimum and we don't care how elegantly designed the transition is.
It is possible to get this to almost work by messing around with various offset properties in the railing but it is really difficult - and then when you have it looking ok in 3D, it gets screwed up in plan and you get warning messages.
And as for that gooseneck setting, I have never seen a goose that has orthogonal transitions in its neck - it is laughable
