It is a given at this point updates will come out for Revit (all autodesk products really) after release. For anyone managing more than about a dozen machines this becomes an issue quickly. The deployment of the initial package and subsequent updates is a nightmare in and of itself but finding the right files is the first issue.
In most cases, a technician of some level wants a copy of the update, wants to apply it and evaluate how to install it as quickly as possible. If they are on subscription (especially after R2) they must go to http://manage.autodesk.com/ or the site autodesk punishes you with for paying subscription/maintenance.
So lets look at where those updates would be?
Ah, here's "Product Updates" that should do the trick:
Nope.
This account has Building Design Suite Premium, Ultimate and just Revit Architecture. And Civil3d. So really? No updates?
Alright, lets see if we can find patches for Revit 2015.
Notice that while I need updates I'm presented with both updates AND add-ins. No way to pick one or the other. The filter kinda works (I will note that if you enable both Revit and 2015 as filters it will tell you nothing is available). Search kinda works. The actual updates are buried at the bottom of this list. Maybe it would be best if I sort!
Notice that I set Newest first as sort. The latest update for Revit 2015 is about halfway down the list. How does this work?
Ok, so I've found my REVIT update. But with Revit Arch you need a special update. Let's change our search.
Really? really? The problem is I'm searching in BDSU, not Revit. So I go to the other product, through the silly popup and do the same thing. Again newest doesn't really work, again the updates are buried. But I can easily find the Portuguese language pack (WTF?).
Fact is the naming conventions vary so "sorting by name" never works well, "by date" seems to work on an alternate timeline, and limiting to a particular package is iffy. The filters sometimes fail completely. Usually our best source for the actual downloads is Luke Johnson's "What Revit Wants" blog.
So how about this:
With 2015 you'd end up with a list of about 26 items AT MOST to weed through. Reality is you'd probably only see about 6 as some of those releases should not be used for any reason.
I doubt ANYONE wants the gargantuan, unsearchable (by browser) lists. Yes it looks nice, but functionally it is useless.
Maybe once this is fixed we can talk about sticking with install strategies?
