Fix bug whereby Dynamo makes Quick Access Toolbar dissapears when above ribbon
There is a bug in Revit 2017 on Win10 whereby if Dynamo is installed then the Quick Access Toolbar is invisible when above the ribbon. When you uninstall Dynamo the QAT appears above the ribbon.  The workaround is to set the QAT to be below the ribbon if you dont want to uninstall Dynamo.
Obviously we don't want people to uninstall Dynamo to make Revit QAT work.
I've had two laptops and both did the same.
Here is the forum entry with other guys having the same issue:
http://forums.autodesk.com/t5/revit-architecture-forum/quick-access-toolbar-invisible-in-windows-10/...
6 Comments
B.Fetzer
Hi !
I've the same problem.
QAT is not visible if Dynamo 0.9.1 is installed.
In this case standard position of the QAT is below the ribbon.
Solution of the German Support: Please uninstall Dynamo. Smiley Frustrated
After unsinstal Dynamo QAT is visible.
Kind regards,
Bernhard
kronz
@charlv Have you tried with the latest or at least more recent versions of Dynamo?
charlv
Yes in the past I have updated Revit to 2017.1 and it seems to have solved the issue.
sasha.crotty
In 2017.2 I do not see this problem when launching Dynamo 1.x so I am marking this as implemented. I do still see this with Dynamo 0.9.1 (only after launching Dynamo 0.9.1), but there are no further updates planned for Dynamo 0.9x at this time.
Tarek_K
Status changed to: Gathering Support
Tarek_K
Forma Design Contest
Technology Administrators
