I discovered a bug today. If you import a CAD drawing for georeferencing that is unitless or in the wrong units and then you fix the units in Revit, it will have the wrong georeferencing location after you import the Shared Coordinates into your Revit file.
Specifying the right units when importing or specifying it into the CAD drawing will prevent this issue. This is a very convoluted bug that could be disastrous on any georeferenced project. If the users are not able to troubleshoot this, it could give them the impression that the georeferencing in Revit makes no sense or does not work.
