Filter's name not fully readable in Filter Options Window as expected
In Revit 2019 we do not see the full filter's name and we can not expand the window as in previous versions. This is important because in most cases we use the filter's name to define it's purpose so the filter's name get's very long. In addition we work with a big amount of filters so this list gets very long as well and often you will have a large list with similar filter's name, where only the last words vary but you can not see them in this view.
I request Revit team for the filter dialog box resize so we would be able to see the filternames in full.
11 Comments
charl.maraisJGPAX
Yes, please. There are other dialogue boxes that aren't resisrable either and we really need this functionality everywhere.
dbooze
I can't imagine why it was decided that the filter window couldn't be expanded and not read the whole filter name.  My company is in the exact situation as the original poster.  Please send a fix immediately!
@Anonymous, please address this issue. It is very frustrating to not be able to read the complete name of each filter. Another one that I've noticed is the Line Weights window, where the scale types are cutoff on the bottom and the row cannot be expanded down. Capture.JPG
matthew_taylor
It makes the horizontal scroll bar in the Filters section of the Filters dialog superfluous.
Don't truncate the filter names = problem solved. 🤗 (Issue persists in Revit 2021.)
vladimir.kruchinin
Oh my god, the issue is still there. Windows are not resizable, there is no slider, no popup on hover and the names are truncated. How many generations of Autodesk employees it takes to change a lightbulb add a drag-resize corner to a window?
jan
please Autodesk: this is a tiny, isolated UI fix that would make a big difference for many users. everyone uses Filters, and everyone needs to name their Filters correctly to avoid chaos, so please give us a better way to stay on top of that!
matthew_taylor
Looks to be fixed in Revit 2023. It's still not perfect, but it's usable now.
irvinFZ3CR
Observer
I am using Revit 2025 and the issue with the Filter box is still not fixed. 👎
matthew_taylor
@irvinFZ3CR Perhaps you're talking about something else?
Because it is fixed. The View > Graphics > Filters dialog box has a drag resizer in the corner, and to the right of the filter names, and a horizontal scroll bar. Also, the tooltip shows the full filter name if it's not fully visible within the list control.
irvinFZ3CR
Observer
@matthew_taylor sorry I think we are talking about different things. Im taking about when I select multiple items using a selection box and then I go to Filter, it wont allow me to extend the Filter box so that I can see the name.filter box.png
matthew_taylor
@irvinFZ3CR - gotcha. Yeah, I imagine Autodesk only thought about regular categories and forgot about links.
