filled region as global rather than per view
Need the ability to change a filled region to change globally rather than per view. if for some reason you have 100 views that you have duplicated and then need to make change on a filled region it currently only updates per view.
Not very BIM and waste of time if I then need to update each view to match the change of said filled region
1 Comment
FG_RVT
welll not to play devils advocate too much but... using filled regions in general is "not very BIM", neither is duplicating said filled region 100 times.
Just create a detail group and and put your filled region in there, then copy that detail group. Now you can edit the detail group and every instance will change.
